best ECU for f22a
    best ECU for f22a
    what is the best ecu for an f22a1 engine?
    new question:
    would a chipped p06 ecu from a civic work with out f22a's?
    reason for asking is because im on ebay but can only find 'chipped civic p06 ecu's" and none for the accords..
    planning on getting level 2 camshaft and cam from bisimoto running on a f22a1 with an h23a1 IM.
    what would be the ideal ecu?
    cb7 rebuild coming soon!
    Need more info...
    With the question asked, the one thats in it.
    Click Image for CB7Tuner.com Beanies, Decals, & Keychains!
      p12, its out of a prelude with the f22a engine. adds like 10 hp. of course if thats what your looking for.
        thanks. would it be a direct replacement? (i.e., taking out the old ecu and replacing it with the P12 ecu?)
          Agreed, with no modifications or set build parameters, the P12 is all we can offer you. However, I'll entertain you...how bout the AEM Series 2 Standalone?
          '94 JDM H22A: 178whp 146wtq
            lol, $2,000 for an ecu is too much for right now..
              The best "plug it in and drive" ECU that you're going to use for the F22A1 is the P12. If you use an F22A6 camshaft and intake manifold (or H23A1 intake manifold), then the PT6 is the one you want.
              A chipped P06 or some fancy standalone system will only be useful if your engine is heavily modified, and you know how to tune the ECU.
                i plan on getting all those. ^^^ selling my 240sx.. i miss my cb7 too freaking much!
                plus, this site rocks!!!!! quick and friendly responses!!
                  which is preferred and most easiest to install for my a1?
                  a6 IM or the h23a1 IM?
                    its a direct plug and play. its really not that hard, takes about 20 minutes.
                      You still haven't said what your purposes are.
                        i just want a slightly modded f22. (im more of a show car guy) but i still wanna give my car some balls.
                          Whats the reasoning for swapping ECU's? are there any downsides to swapping to a P12?
                            i read that the ecu in the prelude 4th gen which came with the f22, (not all) had a better tuned ecu than the f22a1 ecu.
                              Yes, that's it. 135hp in the Prelude with the F22A1, 125hp in the Accord with the F22A1. Engines are identical.
