I'm having a problem with finding out why my reverse lights won't come on. I've changed the bulbs and the fuse but still nothing. All of the other lights on my car work though. Also i noticed my maintenance required light is a dim green like if its not working. Does it suppose to be like that? Can anyone help?
Reverse light trouble
The maintenance required indicator isn't a light. Merely a colored square that changes from green, to orange, to red over 7500 miles (which is Honda's suggested maintenance interval for these cars back when they were new.) It's a counter. Nothing more.
As for the reverse lights, check the reverse sensor in the transmission. When that goes bad, the reverse lights don't come on. Easy fix.
Also, much better with the descriptive title.
Open your hood and look at your tranny underneath you distibutor area.You should see a post like object sticking out with two wires running out.The wires will be green/black the other yellow.Check to see if the wires have broken or come loose or you may just have to replace the whole part.You can snag one at your local junkyard.Sorry i dont have pics to help more.
This is a picture I have from my clutch job --
It might be hard to see, but this is my manual trans. (painted black).
Normally there would be a distributor around here (inlet plugged here by a paper towel), lower radiator hose going back to the thermostat housing, and an air box/intake pipe above the trans. In the red is the sensor. It is threaded in directly from the top. Just grab an adjustable wrench or large pliers.
There is also a rubber boot on the sensor. Chances are pretty good that your rubber boot will have gotten brittle and started to crack. I simple re-wrapped it really well with electric tape all the way around the wires. Good luckLast edited by sin2k5; 01-23-2011, 09:50 PM.
If you have an automatic, the sensor/switch is attached to the shifter inside the car.Originally posted by Junior SmurffNevermind guys, google search works wonders!
I don't have road rage, my car just goes faster than yours!
Accords are for winners. And Grandmothers. But mostly winners.
I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
