cb7 headlite lens...
    hey guys,my project cb7 head lite lens just came out.is there any gud silicone i can use to stick them back together?..my guess rite now is using silicone we use on our windshield to stick them back together or is there anythng else?,i dont like the cheap stuff they will just fall off again..thanks
    are you talking about the corner lense ???
      reply
      head lites bro..the one with big glass lens.
        have you separated the lens from the housing ? if so use some good strong crazy glue, gorilla glue is good also .
          silicone would work fine aslong as u heat up the housing and the old glue with the new glue fused together. should work fine.
            reply
            the old glue is in bad shape,im removing them now as i type this..do you think black silicon gasket would do?
              This is what I use now:
              Nissan Sealant
              You can also pick it up at the Nissan dealer; part #
              Black Housing DIY 1991 Wagon Morimoto Retrofit
              JDM One-Piece Headlight Lens Repair
                When I did my headlights, I used the same copper silicone I used for my exhaust. I'll probably never get them apart again, but, meh, I don't need to.
                Get a tube of 100% clear silicone and use that, let them cure for 24 hours and they'll be together forever. It's not affected by normal heat/cold temperatures (silicone can withstand temps over 600 degrees fahrenheit), it's clear, so it won't leave you with any ugliness, and after it cures, you can clean up any that leaked out very easily.
                  reply
                  @ djcaz_aom,i think thats whats you use when you install a windshield..im talking about headlight lens..
                  @ visualpoet,i had some clear silicone laying around but some how it got hard.haha,im going to buy me a new one.thanks.
                    What happened to your metal clips that go around the headlight glass? I'm assuming they aren't there being that your glass came apart. If they were then your headlight woulda never came apart regardless if it was glued or not. But yeah if your missing them clips hit up the JY and get you some. With those clips the lens doesn't necessarily have to "glued in" just sealed and the clips hold it in.
                      Just so you know, the part I listed is what Nissan uses to seal the lights to body panels and such. Silicone works, but is permanent. Also, silicone can release fumes that stain the inside of the glass and the reflector surfaces. The sealant I am referring to is Butyl and seals really well.
                      I have been customizing headlights for years now, and know a thing or two about sealing them, as well as modding them. In the past I used silicone and learned the hard way by damaging a customers' projector in a retrofit by sealing with silicone. A guy on HID Planet turned me on to the Nissan sealant and I haven't looked back ever since. It works great on rear light housings as well.
                      Just call a Nissan dealer and give them the part number and you will see what I mean. Also, the link I provided is an online dealer that carries the sealant.
                        reply
                        alrite thanks,i will check on that tomoro.nissan autoparts is close rite now.
