not to sure how to set the tension on the belts, drivers side. just put on new water pump, lined up marks to (TDC). need help with putting back belt to the right tension. Appreciate it if can............... frustrating>.<
tension procedure (timing)?
Originally posted by PvillykanacK808 View Postnot to sure how to set the tension on the belts, drivers side. just put on new water pump, lined up marks to (TDC). need help with putting back belt to the right tension. Appreciate it if can............... frustrating>.<miss my turbo cb7
