lowering problem ?
    As far as I know. I know for a fact the ones in South Jersey do.
      to OP any pics?
      and yes im havin this problem too
      i wanna cut the frame out right there but i have no instructions or even where to cut
      when you installed the coilovers, did you leave the spring open at the top?
      or did you but the "cap" over the top of spring
      usually its whats bottoming out on the shock i had to remove mine so the spring is open at the top if this makes any sense
      -Tyler
        Originally posted by tm123 View Post
        to OP any pics?
        Wow... I'm sorry, but that is REALLY dumb.
          Why? lol
          idk if i worded this correctly
          this is what mine look like
          this is what they looked like stock before i removed the top piece
          the top piece was the one bangin the top of shock
          -Tyler
            Well, ok... perhaps that's not TOO bad, as you're still mounting the springs in the tophat like regular springs would be... Though I would assume the designers of the coilover made it that way for a reason.
            Though stock shocks is absolutely idiotic.
              hah cuz im honestly 20 minutes from trenton and i know one near me that hasnt been getting a brilliant amount of service so ill check it out. thanks deev
              Originally posted by rickyduckworth
              that's pretty interesting. when i get that bored i just watch porn and go to sleep
                I just recently put coilovers sleeves on my CB. First I didn't put the bump stop plate in the front so it was bottoming out and almost came through my hood. That said i'm not sure if you mean you didn't put the bump stop or the stop plate on. I thought the bumpstop was supposed to cussion the whole thing and help reduce noise on bumps.
                I think that top part you removed is also supposed to help keep the the shock/strut aligned in the top hat. Did you remove the stock rubber from the top hats on you car? if so that may cause some noise as well.
                My rear passenger rattles because the rubber (not the bushings in the top hat) but the rubber that sat between the spring and the top hat, well it wasn't there so I hit a bump and the top peice you have in the second picture broke. So now, although the top hat bushings are in place i still get a little rattle. I can't find those anywhere for a reasonable price w/o buying another kit.
                Other that a little rattle on the rear passenger side she rides nice.
                IridiumCore
                HCK-The Beginning
                Your drunk she doesn't look that good.
                  well irridium, i did the same thing, and i actually ebayed the top end for the coils and it rattles less than it did before so if you hit that up youd probably see a major difference
                    Yeah, what did you search for I called it a top hat.
                    IridiumCore
                    HCK-The Beginning
