got a 93 accord , i have coilovers, the bump stops have been removed , but it seems that the car is bottoming out and not on the tire ? it has 16'" xxr 002 with 195/50/16 i want to lower the front another 1/2 inch? would love to show pics having problem up loading them ? Q. is has any one have this problem i was told by some its your upper control arm bottoming out you have to cut a area in the wheel well so the upper control arm can travel more ? any ideas just raining have not look yet trying to get a heads up
lowering problem ?
If the camber is set to 0 degrees, then your upper control arms are hitting. They always do, unless you're BARELY dropped. I wouldn't cut your wheel well unless you want to weaken a critical area of your chassis. You can bang it out a bit, or you can run -1 degree of camber. Unless you're completely slammed, that should fix that problem.
If you removed your bumpstops, your shocks are bottoming out. Lowering on stock shocks, especially 20 year old shocks, is extremely dangerous. Not a smart thing to do at all. You should replace those right away. Get a set of stock bumpstops, and cut them in half. You need SOME bumpstop in place.
Oh, and if your camber kit is a $30 ebay special, I suggest replacing that with SPC or Ingalls as well... if that kit breaks on you, you will crash. I know this firsthand.
Expect to pay about $65 each for them. www.neuspeed.com has some of the best prices I've seen.
I woudln't trust anything cheaper. Blown shocks, or shocks that aren't properly matched to your springs, can result in unpredictable handling and braking. Blown shocks drastically increase the risk of crashing.
[QUOTE=deevergote;2695473]
QUOTE]
i have quite a problem then haha. im slammed on no bumpstops. heres a question, do they make aftermarket bumpstops for lowered cars or is it better to just cut the bumpstops?
i also run the camber that i lowered from stock. it looks like VW camber.Originally posted by rickyduckworththat's pretty interesting. when i get that bored i just watch porn and go to sleep
Originally posted by deevergote View PostJust cut the bumpstops.
"VW camber"? No, it's just the trend among idiot VW drivers to have slammed cars with crazy negative camber. It will destroy your tires, obviously.Originally posted by rickyduckworththat's pretty interesting. when i get that bored i just watch porn and go to sleep
Any time you mess with your suspension, you risk throwing the alignment off. Even if you're doing a simple bushing replacement. HOWEVER, putting off the alignment because you have more things to do will only cost you more money in tires by driving around with bad camber (and possibly bad toe.)
Since the Firestone lifetime alignment deal costs about as much as one pair of decent tires, it's well worth it. Then you can go and get your wheels aligned every time you do anything.
