car wont start i checked all fuses nd i pulled the main relay and i had it checked an it was fine my dad has 30+ yrs electrical exp found diagram and tested but the fuel pump i can not hear turning on we checked the connection at pump and it gets power on the connector for a second then nothing where else should i look
fuel pump not turning on
on the fuel rail there is a nut holding down a fuel line . back the nut off and turn over to the crank position , if fuel spray's out it's getting fuel up the the intake.hope this helps man.that's how i checked the fuel pump.the main relay does sound like it is bad. i think that's the only fuel relay we have right ?Last edited by stretch JDM; 12-31-2010, 06:24 PM.
check the power coming out of the main relay to the pump. clean the ground for the pump. its right behind the back seat near the sending unit cover. if you checked the main relay and its ok its pointless to replace it if theres a bad ground or a shorted wire.miss my turbo cb7
Originally posted by quickangel93 View Postcheck the power coming out of the main relay to the pump. clean the ground for the pump. its right behind the back seat near the sending unit cover. if you checked the main relay and its ok its pointless to replace it if theres a bad ground or a shorted wire.
remove main relay
install a jumper wire from the black/yellow terminal(5) to the yellow terminal (7) on the connector
when looking at the tabs on the relay
- - X -
8-6-X-2
7-5-3-1
there is no 4 tab
when you turn the key to the ignition ON position there should be voltage to the pump if there is then replace pump, if there is no voltage check/replace the relay
- - X -
8-6-X-2
7-5-3-1
there is no 4 tab
- - X -
8-6-X-2
7-5-3-1
there is no 4 tab
