Car hesitating
    Car hesitating
    my car likes to randomly hesitate while taking off from a traffic light.also, ill be going about 30mph then push on the gas it will a couple of seconds then it goes.i have already rebuilt the transmission so i know its not that.any ideasthanks
    probably the timing is off...
    do you have a CEL?
      no, the CEL hasnt came on
        whens the last time you did a tune up?
          i havnt done a real tune up on it since ive had it i dont think.wat do i need for a full tune up
            Plugs, plug wires, and I pull off the valve cover and adjust your valves. Just use a filler gauge to check them. I'm pretty sure it's a 10/1000" for the exhaust side valves, and a 12/1000" for the intake. Remember, you don't want to be able to just slide the filler gauge through there with not problem, if you have to tug a tiny bit, your pretty much dead on. Hope this helps man!
            Ninja Edit: Make sure to check your repair manual as far as the measurements go, b/c my memory isn't the best. I know my repair manual says those two specific thicknesses but I might of had them backwards.
            Originally posted by Makaveli2k
            White girls make the world go round. If I were to be stranded on an island and I could only 3 things to bring with me It'd be 2 different white girls. And a Smashing pumpkins Cd... I hear they like that shit. =p
              check the o2, fuel filter, possibly a clogged exhaust system.
                The o2 sensor would be my first guess based on the very limited information provided. If you take a few minutes to look through this section, you'll see about 5 other threads talking about the exact same problem.
                  yeah man i would replace the cheapest stuff first since you say you havent done a tune up...Plugs, Wires, Distributor rotor and cap.. then work from there. by changing that stuff at least you know those are good, and takes out variables. there alot of things that can cause hesitation...this will help you narrow down cause. hope this helps...
                  Ride List
                  1990 Accord dx coupe - my baby (dsm turbo set up in progress) http://www.cardomain.com/ride/3202853
                  2005 Mazda 6s - daily driver http://www.cardomain.com/ride/3171724(totaled)
                  newest 2006 mazdaspeed 6 http://www.cardomain.com/ride/4073987/2006-mazda-mazda6
                    Your car is hesitating due to a failure for air/fuel/spark to come together in the right way. Since you have no check engine light, this is a failure of some of your most basic systems.
                    As has been suggested, start with the replacing your spark plugs, spark plug wires, distributor and rotor. You sound like you're overdue anyways.
                    While you have the cap off, check the ignition coil for proper resistance.
                    Read your plugs.
                    Then move on from here.
                    1997 Honda Accord EX-V6:
                    Originally posted by James Matteu
                    You have to consider the results of your test in an objective manner, or as the country folk like to say, "son, you gotta be smarter than what you're workin' with."
