cigarette lighter help
    my cigarette doesnt work..i need it to work in order to charge my phone and gps im using it...i replaced the fuse for it already and still doesnt work
    Solder
    The cig lighters are setup with a soldered connection for the power wire, I think it was placed there as a safety feature . You probably need to pull the cig lighter out and resolder the connection, I had to do it to mine, its not hard, it just needs to be done.
    201 Whp H22a with bolt ons, see the progress from stock f22a to now HERE
      pull it out and check all the connections.
      did it randomly quit working or has it never worked?
      Originally posted by chessboxer
      We know these are good cars, but for some reason, all the world wants are freaking civics and tegs. Bleck.
      Bought From: Slammed4thGen TypeG x2DeevergoteBillKisme
        seems like a dumb question but did it somehow get unpluged from the back... just asking because i remember it happen to me i checked the fuse and everything but i guess when i let my sister in-law borrow the car she plugged her phone but when she pulled the charger out she pulled the whole cigarete lighter out it came undone she got scared so she just screwed it back on but the wire came off she dint tell me anything till weeks later and i was like duh! why dint i check that... just a thought...
        MRT http://www.cb7tuner.com/vbb/showthread.php?t=175158
          it has never worked..i guess ill check it up whenever its not raining then..thanks guys
            really mine had like female and male tabs like the ones on radio wires
              If you can get to the back of it, they have a metal sleeve that threads on to hold the assembly to the console. I believe it also acts as a sort of ground, so it need to be tight to operate reliably. This was my issue anyways(after I had ordered a new one from the dealer)
