hello i have a 92 accord coupe i wont to do some suspension work on my car i wont to replace all the bushing.I just did my axles now were is the best place to get the performance bushing set. i also wont to do performance shocks and coil overs.I wont to do all of the suspension before i turbo it thank all of yall for your time
Suspension for 92 accord lx
im guessing you "wAnt" to do those things so id say look at the junkyard, go on ebay and browse the web, hell even go to a local parts store and maybe theyll have what you needOriginally posted by rickyduckworththat's pretty interesting. when i get that bored i just watch porn and go to sleep
You'll get bushings alot cheaper offline than at a parts store. Please use capitalization, spaces and periods correctly. It makes it very difficult to decipher when you don't.
You'll want the energy suspension front control arm & strut rod set(s). You'll have to buy the front ES shock mounts separate because they don't come in any kit.
For the rear you want the Prothane rear control arm bushing set and the Moog rear shock mounts. The rear upper control arms are cheaper to buy whole new units with ball joints, TASauto or hondapartsdeals.
I recommend you also replace you front lower ball joints with ONLY oem parts. If they aren't already wearing, new suspension bushings will surely make them begin to wear soon. Since you are lowering the car you'll want a front camber kit. I recommend front upper adjustable ball joints by SPC but you can also buy the adjustable anchor bolt kits. IMO may as well replace those upper ball joints and get adjust-ability at the same time. Summitracing is a great source for most of these bushings/ball joints.
I'm glad you're doing it right with replacing the bushings first. Don't put off getting an alignment immediately after. Keep us posted, post pics.My Member's Ride Thread
just cut the springs!!! well dont really, i mean you can, just wouldn't drive around for too long. function and form type one or two are awesome!Accord SE
93se
Members Ride
Bought from: H22wagon93, Theos92VR4, Hondafan81, Father Time, DarkHusk, Gunrunner, FamousFreak
Sold to: sulimed, BurtonRiderT6, tishock
I would really rather not have one more moron riding around on cut springs... there are enough already. It's a bad idea. Don't ever suggest it, even in jest. Cheap-ass idiots won't see the danger, or the fact that you say it's a bad idea... they'll just see "oooh, a cheap method that I never thought of before!"
Bushings: Energy Suspension or Prothane (if those are still made.) Buy them online. A "master kit" usually runs about $100.
Shocks: Koni STR.T (orange) if your budget is limited, and you don't drive your car hard. Koni Sport (yellow) if you want shocks that will really perform. The Yellows are adjustable, but more than twice as much as the STR.Ts.
Unless you're going to get crazy with custom valving and such with the REALLY good brands, such as Bilstein, Penske, Ohlins, etc... then Koni is all you need. If you're going to lower your car, I wouldn't trust any other affordable brand (such as KYB and Tokico... not bad companies, but they can't compare to Koni for performance and safety, and their prices aren't much better). Any parts-store garbage like Gabriel or Monroe... stay away.
Coilovers... if you're talking about adjustable sleeves, the ONLY brand I would ever trust my own life with (and that's exactly what you're doing with your suspension mods...) is Ground Control. You can get a custom spring rate from them as well, so you can get EXACTLY what you need. If you don't know enough about that sort of thing, now would be a great time to learn... BEFORE you buy.
Don't forget about camber correction, alignment, and good tires.
