Engine swaps
    Engine swaps
    Please forgive my forum noob question, but when I search, my browser freezes....
    What are all the engines that will swap with minimal work. Ones that match almost perfect with no major mount work or fabrication needed?
    http://www.cb7tuner.com/vbb/showthread.php?t=159041
    My 5.7 LS1 Holden Ute
      H22 bolts in.
      COUPE K24
        Thanks, sorry for the noob thread post...
          Don't worry about it, this is the "noob forum".... That's what it exists for. That way hopefully after 30 posts(which normally is 30 "noob questions"); when you can enter the other forums most of your threads will be more in-depth and can actually contribute to the overall value of the site.
          '94 JDM H22A: 178whp 146wtq
            Now i have a diff question.
            This website has engine available for swaps, but i'm confused on what these terms mean...
            "H22A 92-95 Motor, Tranny, Computer"
            or
            "H22A 92-95 Complete Change Over"
            What's the difference?
            http://www.hmotorsonline.com/shop/sc...Engines&hit=15
              look at the parts your getting thats why theres a price diffrence one comes with axels shift linkage motor mounts etc.
              or
              MRT http://www.cb7tuner.com/vbb/showthread.php?t=175158
                change over = complete engine trans harness axles mounts wiring harness ecu
                COUPE K24
                  So, then it's obviously better to get the complete change over....
                    usually if its a good price. a place here has an ENTIRE front clip of a 92-95 prelude for 2200$.
                    COUPE K24
                      The one I'm looking at is 2099 + S&H
                        thats not too bad.
                        COUPE K24
                          So i'm guessing from the recation, that's a semi-normal price?
                            You really don't need anything more than the engine, ECU, and trans. I got the complete changeover, and I have a basement full of parts I'll never use. It did, however, come with all accessories.
                            hmotorsonline.com isn't the cheapest, but they are the ONLY place I would trust buying from. The cheaper engine sellers often sell crap. You CAN get lucky, but with hmotorsonline, it's not luck. They just sell good engines. In the event of a problem, they'll make things right.
                            and for future reference... if the search function of this forum doesn't work for you, go to Google and type in what you want. follow it by
                            site=cb7tuner.com
                            and it will search this site only.
                            OR, just click through the "sticky" threads at the top of each section. That's where most common information is found. The list of engines you asked for can be found at the top of the "swaps" forum.
                              so if i just get the engine, ecu, and tranny then i shouldn't need anything else?
