"popping" noise
    "popping" noise
    ok so this is my first post on a forum i home to become a big part of. well first off i have a 1992 accord ex with a F22a. i have a kind of weird noise when i hit near redline. if i let it go on the clutch or if i let off the gas it sort of "pops" not loud but like enough to notice but not obnoxious like a backfire or if you have a limiter that allows that. any help i would appreciate it
    and this usually happens when it runs just under optimal opperating temp
    Originally posted by rickyduckworth
    that's pretty interesting. when i get that bored i just watch porn and go to sleep
    have you done a simple compression check? me thinks it may be something mechanical.
      sounds to me its back firing man. just not a big one.not a biggie.
        check your ignitor connections inside the distributor (all the crimped connectors). I had this happen to my H22 when I first swapped it. A couple of the wires inside weren't making proper contact and were not transmitting all the spark...thus causing the popping in the high RPMs
        I simply coated all the contact terminals with dielectric grease and that completely solved the problem for me...going on 2 years since and it hasn't come back once.
          i noticed today that it was like more burbling and nt a pop. it has done this after i checked the dit. and the wires werent connecting i guess. good looks
            Do you have an aftermarket exhaust? I notice if I dont have enough back pressure on my cars, when I let off at high RPM i get the same "pop" sound.
            350z- Injen CAI & CB, Stillen testpipes & headers, kinetix SSV plenum, TEIN SS coilovers
            90 LX- a6 conversion, 2.5in exhaust
              That happens to my cb7 when i would let off the gas the exhaust burps this happened after i Installed a catback
              Originally posted by Gummiegorilla
              Damn CBs are like a Rubix Cube sometimes !!!!
