f22a1 / f22b1 vtec head swap
    would this be a basic bolt on process i kinda wanna do something clean and easy. now i would like to know how much gain i would get out of this as well. iv been trying to do research on this now im here asking you guys, also around how much would i be spending if this was possibile. thankssss
    It can be done, but there is alot of work involved in it. More then just bolting up the head. Headgasket change, ECU swap, Vtec lines/wires. What exactly are you wanting to get out of this change.
      boosted i guess something under 2000 $ =p
        Most will tell you its a waste of time.I have a full b1 swap in my cb.I can tell ya it runs pretty good better than most I/E f series ive ran up on or rode/drove.Is it a 4 length car puller over the others?NO but decent for how crapy the heads on the b1s flow.Your stock head flows better than the b1.Ive seen/read some F22Ax with the head swap and say it helped maybe 10-15hp idk i dont tend to believe everything i read or hear.Heres my opinion if you cant get the head IM and ecu for under $100bux dont do it.It would be cheaper to save yourself the hassle of hunting down the parts and with a head swap comes New HG,water pump,timing belt,VC gasket set,Pining the ecu and run wires for vtec.Im pretty sure the intake manis are different aswell as a few more odds and ends.Save yourself the trouble,and get either a delta 272 cam or a bisi cam an a few bolt ons would yeld more power gains than the head swap.Dont get me wrong i love my b1, but since mine was in it when i got it im going that route instead of a F22Ax.
        02 Crv
          The only thing your gaining until you boost it is a cam that is weaker then your current cam until you get a to a higher rpm.
          It is not going to make your car faster.
          sr20det,rb20 etc all these cars are bootsted and non vtec and make great power.
            If you want something fast for under $2000, boost and get it tuned. If you want vtec buy an h22 and swap it. Its probably the easiest swap to do.
              You'll gain no more than 5hp over an F22A6 by doing the head swap, and you'll be installing a head that has less overall flow potential. It will offer no additional benefits for boost. All it will do is increase the number of parts that you mess with. When you're a beginner, remember that each part you touch with your wrench increases the likelihood that it will fail.
