I know I am new to these forums,so I will be nice.
I am going crazy stuck in newbie forums with every other thread people wanting to slap a H head on there F block,assuming they will gain the power the H series motor puts out.
Here,hope this helps.
It will not do anything other then cause your stock F bottom end to come apart.
It is not able to handle the high rpm's the H22 is designed for.Also the H22 is not a B16a or a B18c5 so 9K is asking for problems.
Your F motor vtec or not is a great motor with tons of potential.It will not be cheap.
Boost with a good tune,quality parts and arp fasteners vtec or not can make great power.
You can swap a jdm F20b or H22a for less then a good turbo set up.
You can also build your F motor for spray or just a high cc N/A.
Please stop thinking that Vtec has anything to do with the power or the rpm's your car can safely achieve. vtec is nothing more then the way that Honda gives you both fuel economy and good power.
If you want power vtec or not a high compression f motor with a nice cam,mild port and polish,even a gasket match and polish with a nice 4-1 header would be nuts.
All this aside you will not gain more then a swap.
So it's back to the old saying.You get what you pay for.
200+hp fun for less then $1500 is an H swap with p28 chipped/tuned
200+hp fun for $2500-$5k for a good turbo and tune(something that will last for a daily)
190-225 F motor build $2500 should get you there if your doing the work.
$500 H head on stock F block,your selling that heap on CL for $500 after you blow it up.
