ok so i got a killer deal on a f23 vtech and i got a f22a4 in my accord now i payed 50 for the f23. i was wondering if i put the f23 head on my f22a4 bottom would tht be betr or should i just drop the whole f23 motor in my car??
f23a1
Originally posted by reboklan View Postok so i got a killer deal on a f23 vtech and i got a f22a4 in my accord now i payed 50 for the f23. i was wondering if i put the f23 head on my f22a4 bottom would tht be betr or should i just drop the whole f23 motor in my car??
The F22 is really a better motor design than the F23.
My 5.7 LS1 Holden Ute
Originally posted by reboklan View Postnothins wrong with my f22 i just wanted the sohc v tech head
An f22a6 makes 140.
Not to mention but the only thing making the f23a1 better then the f22b1 is the 2.3 liters
You'd be making an f22b1
And to top it all off that motor isn't easy to swap. Get rid of it, flip it for profit.
The valve angle and port design are very restrictive in the SOHC VTEC F series. Power can be made, but a person should understand what they're getting into. Most just want cheap VTEC, and they don't understand that the SOHC F series VTEC is significantly different from the VTEC system found in the DOHC engines (for example, it's only on the intake valves.)
The F22Ax offers FAR more potential than the VTEC F series.
Originally posted by pebojelly View PostWhy do people say that a single cam is pointless for power?
The only thing weak is the way it is ported to max torque for fuel economy.
The entire concept of Sohc Vtec is fuel economy, not power.
Its a reverse concept of Dohc Vtec.
Imagine an F22 Non Vtec (your current motor) Now add smaller valves with less lift/duration to that, then combine it with a map that injects less fuel (while vtec is not engaged)
The result is a more fuel efficient engine while Vtec is not engaged, and the same engine when Vtec is engaged.
There ARE 250+whp N/A F22B1s out there, I'm told... and I'm also told that the F23A1 head has a better design than the F22B1 (though still restrictive.)
They're not absolutely pointless, and I'd say they're not bad choices for a street turbo build... but ONLY if you know what you're getting into, and why. If it's just because "you wanna pop 'tec"... then look elsewhere.
At least he only bought the motor for $50. Sell it for like $250 to some guy with a CG with a blown headgasket or something. Then use the $200 you made to go get a tune up and a fresh tank of 93.'94 JDM H22A: 178whp 146wtq
Originally posted by deevergoteIf you say double dutch rudder, i'm banning you...
