Broken Vacuum Tank Nipple by the battery - Important?
    #36
    Is this important? what is the function of this box?
    I think it been broken since i got the car. When i did h23 im swap i just removed the hose completely
    It is a vacuum solenoid to close the valve in #16 below 3500 rpm to reduce intake noise. Without vacuum applied to it, the valve is always open allowing air into the filter box via both the upper tube (#12) and the lower tube (#15, #16, #20). You are not using #36, so you can remove it.
      it's almost like a thermostatic air cleaner
        that is very interesting.
