Bisimoto Level 2 Cam Question
    So I'm instaling a Bisimoto level 2 cam and cam gear.
    Motor F22a1:
    I have intake, header, and exhaust qith a stock bottom end.
    My question is, will my sock piston clearance be good with this setup?
    It should be fine. However, did you replace the valve springs, as recommended? Valve float may be an issue otherwise.
    Your other bolt-on mods have nothing to do with valve clearance.
      best thing to do is freshen up the cylinder head to take advantage of the cam. while the head is off, you can clay the piston and check the clearance and possibly run a thinner headgasket for more comrpession since it will need tuning anyways.
        damn beat me to it
          Thanks for the replies you guys!
          When I invest a bit more cash I'll aim for the valve springs, potentially smaller headgasket, and I hope some 11:1 pistons and some other internal goodies.
          If you'd like I'll note my gains, or pros and cons.
            No sense in installing it w/o them
            Bend a valve + pop a piston = car down unplanned and you have to spend the $$$ and time to do what u were supposed to anyway. Not to mention you're gonna have to install the cam + fix the lash + get it tuned twice. Makes no sense
            Originally posted by lordoja
              cams, especially anything over level one should only be installed with all the respective parts as well such as springs AND retainers.
              When installing a cam properly you should also degree the cam in order to get the most out of it, otherwise you can seriously limit your possible power gains.
              member ride thread
              DIVULGE MOTORSPORTS
                Motor F22a1:
                what ecu are you running?
                cb7 rebuild coming soon!
