Car wont start after changing the radiator???
    So yesterday I changed out my old radiator that was held together with quick steel from the pev owner. So i started to take everything out and let the antifreeze drain out and had to take off the horse from the lower radiator but i discounted it not from the radiator but from the other end and let the fluid pour down. The fans wont coming out very easy so i cut the wires and when i put the new radiator in i had a issue with those damn tranny cooler lines and i taped up the fan wire back together and left the a/c fan out and started up the car and saw one of the tranny lines just pouring out so i shut off the car and tighten it and tried to start up the car but nothing! I think its either the battery or starter. But when i turn the key no lights or anything but if i come back ten mins later the dome light is on but once i turn the key. It all dies! Help me please on my daily. Thanks
    Bought from:AbsurdNY,92smokeaccord,cb7inct,nevi325,xkjnboix,cb 7resurrector,JoshM
    MRT: http://www.cb7tuner.com/vbb/showthread.php?t=203451
    if you have some jumper cables , get you a jump. sounds like you may have a dead batt.also when you get the car running , see if the wires are on correctly ( the fan ) make sure its not staying on and running your batt. down.
      Well the fans dont turn on lol i just wired them back you know the same color to the same color
        have you checked the voltage on the batt. ?
          No i havent but im going to be going to walmart in an hour because its for 7/10 so they will give me a new one lol
            good deal man . keep me and the rest of us posted.the process of elimination can be a timely matter. good luck man i hope you get her back on the road.
              Thanks man and i will be back in afew hours
                just got back and they said its good. so ill go reinstall it and see what happens
                  your battery terminal might be loose.
                  make sure it tight down and put some of those anti corrosion gel for battery terminal
                    UPDATE!!
                    Just got back in and nothing! Once i hooked up the battery there is life in the lights but once i turn my key one click it goes out. But then i take the key out and wait a minute and there is light again.
                      make sure to also look at the batt. cables. try to take the wires out of the clamp on the - side. rewire them. check the fuse box inside and under the hood.if thats all good look into a starter. search around the starter for loose wires and the ground wire.good luck and don't worry you will find the problem.
                        Figured it out
                        The ground wire from the battery was all messed up so i taped them up real fast to see if it was the issue. And sure enough it tried to start.. Im sure i could have gotten it started but it was raining so much i just wanted to get in!
