VTEC Pressure Switch
    well i finally got my car on h22a
    and it throw out some codes first 14 then 22 and 21 fixed them all except 22
    thats VTEC Pressure Switch (Power) but i have a jdm vtec selnoid only has the grey blug with green wire
    how do i fix this aslo vtec not working
    Just replace the vtec selnoid and it should work and make sure you check all the wire that is going to the vtec selnoid and the ecu.
    92 cb7 http://www.cb7tuner.com/vbb/showthread.php?t=176886
    91 cb9 wagon
      how much are they
        Diff price maybe check on ebay or craigslist
        91 cb9 wagon
          so i cant use mine
            make sure the vtec wires are connected correctly, i had the same problem on mine, found out the wiring on the ecu was jacked up.
            My MRT!: http://www.cb7tuner.com/vbb/showthread.php?p=2800644
              well im shur everything is good but ill double check
