I think my Proportioning valve is leaking
    I was able to reach down and snap this pic
    I dried off the area, then stepped on the pedal and when I checked again new fluid leaked out, seems to come from that hole.
    Is that hole supposed to be plugged up?
    Also, how do I replace this part?
    TIA
    i would start by getting a haynes or chilton. they can be very helpful. i just replaced mine a few months ago and it really isnt hard to do
      Was that hole supposed to be plugged up?
        its been awhile. i cant remember off hand. its to dark out or i would go check for you.
          It looks threaded, can't it just get it plugged up with a bolt?
          I don't have anyone to look for me while I press the pedal but that hole seems like the culprit if it was supposed to be plugged up.
          Also, I moved recently and don't have access to my haynes, can anyone post up directions?
            sorry for bringing up an old thread, but i recently changed mine out with one from the yard... about 3 months ago worked fine but now i just did my brakes and changed out my caliper and once i finished bleeding it i noticed i started leaking from that middle hole ( which has like a little black button ) does that mean this one took a dump to? plus who else carries a replacement? i just called honda and they want 250$ for a new one :'(
              When u put the new one in did u swap the mounting bracket from the other one on if it wasn't accord > accord? If it was a 40/40 from a da u have to swap the accord mounting bracket over. If u did this it did u have the valve clamped down in a table vice? If not the valve like to spring open.
              And ur immediate seal that it used to have is now interrupted. And possibly leaking due to that. Check the tightness of the fittings going into it before removing it for another. Using a brakeline wrench.
              (129)Transactions and counting
                Yeah, there's supposed to be a very small rubber cap there, just don't ask me how the rubber holds the pressure back!
