Got a question im going to upgrade the cam in my h22. Getting a valve train upgrade as well. Anyone know if it will still run right with the stock p13 computer or would i need to upgrade to a hondata computer?
H22A Cam Shaft Upgrade
Originally posted by 1991accordh22a View PostGot a question im going to upgrade the cam in my h22. Getting a valve train upgrade as well. Anyone know if it will still run right with the stock p13 computer or would i need to upgrade to a hondata computer?
eCtune
Neptune
Crome.
Pick one.
I made 620 WHP on Crome for over 2 years.. Not only is it free, It will do EVERYTHING youd need.
eCtune and Neptune are both VERY solid. I run eCtune now. Its really nice and EVERYTHING works well... Obviously LOL.
Fuck Derek
Fuck Doug
and FUCK Hondata....
Not to that this matters but the boost control eats a dick in it too. Let alone wat those ***s tried to do to Blundell and the entire DIY tuning community750 WHP/575 TQ CD5 Raping a street near you....
realHomeMadeTurbo.com / Kaizenspeed.com / LSD Motorsports / Tempest Racing /SpeedFactory /ExplicitSpeedPerformance
GFI HOLLA!!!!!!
http://www.youtube.com/watch?v=Cdiz0k0Rudw
Originally posted by Supergenius View Postget it tuned....
eCtune
Neptune
Crome.
Pick one.
Fuck Derek
Fuck Doug
You don't need to buy a pre-modified computer. Buy a bone stock P28 (from a 92-95 Civic EX) and have it modified. Then you can tune your car with any of those programs mentioned.
Now, your H22 has 2 cams... I hope you're upgrading both! If you get a mild grind, the car should still run well enough on the stock ECU. Most "Stage 1" cams from reputable companies are mild enough. Most "Stage 2" cams will still probably run with the stock ECU, but not very well (and this is where you'll definitely need that valvetrain upgrade.)
Either way, you'll get the most out of the cam upgrade with a proper tune.
Originally posted by deevergote View PostHe's already getting the cams. He's asking if he should tune for them. The thread is about the cams, not the tune.
Actually, since the P13 runs rich, it might work BETTER with bigger cams.
Problem solved question answered.750 WHP/575 TQ CD5 Raping a street near you....
GFI HOLLA!!!!!!
Originally posted by Supergenius View PostInstall cams.. Chip ecu when you can, then tune.
Originally posted by deevergote View PostYou cannot tune a P13. You need a P28 or P72.
You cannot run either the P28 or P72 stock, so you must chip and tune to run one.
Therefore, install your cams, use the P13, and get a tunable ECU when you can afford it.
for my setup i decided to get a P06 with hondata before most of my mods
just my 2 cents
