f23 aftermarket rod possibilities
    Saw BC makes a set but will set me back 750.00 and i was just checking if there was another setup to run. Running k20 forged pistons and turboing the car. Looking to push alot out of it after a while (June). All else fails i will get the BC setup but just wanna see my other possibilities. May de stroke the engine if possible so i can rev it higher (atleast 7.2-7.5K). Thanks in advance folks.
    well guess no one knows... what about the f22? I saw Scat which I know someone has a set of for cheap but are they reliable? And what about a piston setup for this too?
      bisi might have a set of f23 rods, im not 100% sure on that though. I know he sells f22 rods. Give him an e mail and he can tell you.
        anyone know who i should email or what email to use? i emailed randull at bisi but got no reply.
          compare the specs and see if they are compatible. im pretty sure the housing bore is different though.
            i relly want to no if this set up works. i going to look in to it. what about the crank dont u have to change it is u change rods? .... and the ecu?
              yeah, the f23 and f22 rods/pistons are completely different. there is a way I have heard you can destroke the f23 but keep it a 2.3L by putting a h22 crank or something of the sort into the engine, but for the price, I could probably have my whole turbo kit. I decided im gonna just look into boosting my f22b1. Found some scat rods a buddy has for cheap, just looking for some pistons now. anyone have an idea without spending 700.oo?
