i need to replace that Clutch Release Hose, can anyone tell me how to install it in my car? please help,its number 15 in the figure shown above
Clutch Release Hose Leakage
it's a really easy.
One side you WILL NEED a flare nut wrench and the other side is just a banjo style fitting which you can use a socket set on. I say you need that flare nut wrench because you'll be rounding off the edges of that fitting where it mates to the hydrolic lines using an open end wrench.
You can find a good set at Harbor Freight for about 10 bucks instead of going to Sears like i did for mine.
Which year Accord do you have again? I was going to suggest, if you could wait and you have a 9293, you could order the stainless steel braided line that TAS is selling for 30 bucks.
Since you're doing it now, you also might as well as replace the slave unit #11 in the picture. Don't forget to bleed the system after replacing that line.
(edit) poop, i just noticed you were in Saudi Arabia so all those stores i suggested you can probably forget about finding.Last edited by Leung; 11-24-2010, 08:06 AM.
