Foamy, overflowing power steering fluid
    The power steering fluid in my '91 EX bubbles up to near the surface of the reservoir and then spills out the top of the reservoir once I shut the engine off. This seems to be the case regardless of whether I am driving, warming the car up but not driving anywhere; and regardless of whether I steer hard or don't steer at all.
    This is a recent problem. Prior to this, my car was out of commission for about two weeks since I was waiting on a new distributor and ICM. I installed these last Sunday, and after starting my car and warming it to test the new distributor, I noticed a funny smell and followed it to the puddle of power steering fluid that had formed on top of the PS fluid reservoir.
    It has been cold lately where I am, if this means anything. I know the PS fluid isn't suppose to freeze. The hoses look fine. I'm going to clean and dry the area. It's hard to tell right now since the fluid that spilled is still on some of the hoses and in the engine compartment. Fluid level is/was also fine - not too high and not too low. Lastly, I DID use Honda specific PS fluid.
    Any ideas?
    91 EX, body/chassis ~235,000; rebuilt f22a6 crate engine ~65,000 (3/2011)
    Neuspeed Super Cup Kit (7/2010)
    TAS rear drum-to-disc conversion (6/2010)
    Above photo taken - 4/2010
    Air in your system.....
    CB7Tuner Resident Gamer!
    PSN: JDMcb7TX
      did you get a new steering rack recently?
      if not, it sounds like the system is sucking in air somewhere.....
      92ex CB7<-SOLD 93ex CB9shiftingshift73C10
        Look for leaks.... You are getting air in your system from somewhere...
        PSN: JDMcb7TX
          No new steering rack. Why do you ask?
          I'm going to degrease, rinse, and dry the area - then inspect for leaks.
            Areas susceptible to leaks?
            Are there any areas more susceptible to leaks than others that I should look for?
              i replaced my steering rack and had wicked foamy PS fluid... the whole system is a bitch to get all of the air out...
                turn the wheel with the engine on left to right all the way till the steering stops, that should bleed the system.
