**H22 trans questions**
    Ok i didnt know where to put this so i put it here.First off ive nvr dealt with auto honda trannys before other than pulling engines and tossing the trans away.Ik i can do the swap in a days time.Heres my questions...
    Will i need to use a h22 stall or can my stock f22 stall be used?
    Will my stock trans cable work?
    Will my stock f22 axles work?
    Will i need to get def half shafts?
    Will the tcu im using work?
    Im wanting the closest auto h22 or 23 geared trans as possible F22 trans is entirely to long.Which trans would you suggest?Car will not be raped 24/7 mostly track and maybe a few fun runs elsewhere.Car is a 4dr cb7 with a f22b1 healthy engine not one hiccup.That will be the power plant im sticking to.Car will have bolt ons and a 272 cam and a cam gear all in good time atm its just swapped,intake and cat back.Not expecting a 11sec 1/4 car lmao just a lil more ass.Any other info to add is welcomed such as gains,swap info,reliability pros and cons etc....Thanks in advance.
    02 Crv
    I'm not too sure about the auto tranny, but it should all be direct fit, the axles will work as well, the only thing I'm not sure if it will work is the tcu.
      Thats what im hoping....Ive never did an auto trans swap and ive did a number of engine swaps and manual trans swaps.Im just trying to know all before i get into it so it wont take more than a day and do it right the first time.Its better being safe than sorry in my book.
      02 Crv
        If someone could give me dead on no if ands or buts about this that would be sweet!
        ummmm also need some of the auto h22 gear ratios i looked at the link on here and found only the auto h23 ratios.Thanks again!
        02 Crv
          Running a 93 tcu...
          wheres the tranny code on the autos btw?cause im not seening it.Should be a sticker on the front of the case correct like on a std trans or is it else where?
          02 Crv
            Use stock axles
            Use stock or h22 stall
            use h22 tcu
            stock shift cable, stock kickdown cable.
              Originally posted by bruno8747 View Post
              Use stock axles
              use h22 tcu
              Good deal...Now to find a trans.
              02 Crv
                Use stock axles
                use h22 tcu
                agreed 100% i have a mp1a lsd tranny and in order to use a h22 tranny correctly it has to be paired with a h22 tcu which is the p19. other wise the shift points well be wrong and you well be dropped out of vtec between gears.
