I'm looking to do a battery relocation and i was wondering how you would run your wires for the relocation?
battery relocation
It's not worth the effort unless you are going for a full show/tucked engine bay.
To do it right you'll have to get a quality relocation kit. But in the end you are gaining absolutely nothing. If you are doing it for performance/weight distribution, then you are better off just getting a ~10lbs battery.
Originally posted by WhiteGirl View PostIm putting my batt in my trunk can i run the wire stright from the alt to the batt or do i need to wire it diffrently?
Here's how I did mine:
Don't mind the yellow wire.
And here's where I fed it through the firewall. Just under that black canister there.
^it pops into the floorboard by the ecu. Then you run it under the carpet like Tommi said, and back behind the back seat into the trunk. Oh and that grommet there is solid, no hole. I just drilled out a hole big enough for the wire and fed the wire through.
And I just mounted the ground here, basically on the side by where the battery tray was.
Hope that helps. Let me know if you have any questions.
-Kim
Originally posted by CRX Toad View PostIt also needs to have a fuse on it somewhere. Closest to the battery. Also you needs a sealed battery or a battery box that is vented to the outside.
Edit: unless you are doing this for track purposes. Also for track use you would need cut off switches too. And the boxes only apply for wet cell batteries. For dry cell no box is required.Last edited by sikz6; 05-27-2011, 07:33 AM.
Nice DIY images.
Originally posted by sikz6 View Post
-Kim
/back on topic
Originally posted by GhostAccord View PostNice DIY images.
Do you use your AC very much? That hose just to the right of your battery wire that is bent up out of the way is the condensate drain for your AC unit. That black box will fill up and the water will start to stagnate, or worse, leak out onto your carpet and possibly short out your ECU. Just somethign I noticed
/back on topic
