Ok so for the past 4 weeks or so I have been noticing a decent sized oil puddle under the drivers side of my cb-below the timing cover/belt area. Checked with Nic and he said it sounded like the balance shaft seal. Went and picked one up at Honda and was wondering if tthere was a thread or diy on here that I can't find...don't have enough change to take it to a mechanic so I got to do this one myself. Any help is appreciated!
balance shaft seal
i just bought : Timing Belt,Balancer Shaft Belt,Water Pump,Camshaft Seal,Crankshaft Seal,Balancer Shaft Belt Seal + OEM Honda Bracket for the Balancer Shaft Seal (The seal pop out if you dont put the Honda OEM Bracket).........
Do i need to change the Timing Belt Tensioner ? The Oil Pump ? The Oil Pump Seals ? ...
My cars is now at 132 500 KM .... Im the second owner...Mint CB7
