Okay so i have replaced my upper and lower spark plug seals along with the valvecover gasket. I did a oil change after and Im leaking oil somewhere.. i think its my Oil Pan Gasket.. anyone had a big oil problem? If so please tell me where. Thanks
Oil Leak
I would check everywhere I could to see where it's coming from also sometimes belive it or not it does leak from the valve cover gasket or check this out hope fully it helps .http://www.youtube.com/watch?v=wYU8qtPzQOYLast edited by BILLYBOPROCK; 11-22-2010, 03:09 PM.Destiny Struggles To Reassert The Pattern That Was Meant To Be. Also Some Of These Members Are Wise Guys With There Wise Guy Answers . Also only inexperienced drivers put donuts in front . You can follow me but it's going to hurt!
So as I read your post, are you saying that you saw an oil leak and just replaced the seals without even knowing it was the problem?
Next time, wash down your engine, make sure its clean, and then run the car and then afterwards, put a drip pan underneath it. and that will save you time and money.
clean up where you see oil, and check every day till you see where its coming from, a lot of chances is that might be oil pan gasket.AT WEST COAST MEET
cb7rush: who has the tongs?JDMxDB8: i got a thong on...
to get to see more of my cb click the link below.
http://www.cb7tuner.com/vbb/showthread.php?t=130922
