need help with moter work
    well i have a 92 f22a6 with 198000. i did a head job and i got it all done and its running relly bad. so i thought it was the timeing. come to find out i have no compression in cylinder 1. it ran good before i did the job is i whent to do the spark plug tube seals. the timeing i messed up and bent vavles so i got anuther head then had it redecked. so i checked the valves in new head and they are all sealed. then i find out with the new head on the car i have no copressionin cylinder 1. lost now and dont no how to fix it please help
    Sounds like a valve issue still man.Could be burnt,bent or droped.Usually rings wont give a 0psi compression reading.Atleast ive never ever seen that, but valves will.
    02 Crv
      do a leakdown test, that will show exactly where the leakage is
      instagram @mikeymeyagi
        i poored water in them. they did not leak the the 4th cylinder leaked but that had the highist number out of all . but 1 didnt leak and it has no compresshion when i tested it . the head is off my car and what test can i do to see what is good and bad.
          are the valves being kept open? make sure there is valve lash.
