H23 pistons/rods in f22 block?
    can it work? of coarse it needs to be bored, but could you put a set of h23 rods and pistons in an f22 block? or would I be better off just getting f22 pistons for my block? or just maybe keeping the f22 rods with the h23 pistons? thanks.
    h23 rods are the same as f22 rods. Boring from 85mm to 87mm isn’t smart
    R.I.P Rex 10/10/97-08/06/09
    There aren’t enough words in this world to say how much you will be missed. love you buddy!
      alright, i didnt this it was a 2mm difference.
        why isnt smart to bore to 87mm?
          well 87mm can be done on a stock f22a easy but thats it....i belive wed3k is doing this with out sleveing the block...only down sides is when the time comes to hone for new rings u cant do it as the block is at its peak so new block and bore are in....and it will be way easyer to send a rod threw the block...imo
          my new turbo build
            H22a/H22A1 Crank (50mm journal) - H22 Eagle rods- Wiseco EVO stroker pistons.
            PROFIT
            Bore size has nothing to do with sending rods through blocks...
            Remember: RPM = Ruins Peoples Motors
            750 WHP/575 TQ CD5 Raping a street near you....
            realHomeMadeTurbo.com / Kaizenspeed.com / LSD Motorsports / Tempest Racing /SpeedFactory /ExplicitSpeedPerformance
            GFI HOLLA!!!!!!
            http://www.youtube.com/watch?v=Cdiz0k0Rudw
              well, the reason why i asked is because it would be cheaper for me to just use the h23 pistons, because i bought an h23 motor and the cyclenders are scored to fuck. but the pistons look great, and i have 2 f22 blocks laying around so i was just going to bore one out. Is there any difference from the h23 and f22 rods? Are the h23 rods stronger?
                the .1 comes from the bore, stroke stays the same
                its a good swap
                concentrate on the head part of the swap
                Just do what PR CB7 said.
                  Thisss is a good ques.
                    im doing it with h22 pistons for the compression. it's going to be .040 out of the hole but you're going to need a custom headgasket anyways.
                    i need a torque plate to finish honing it and a car to put it in since i dont have my accord anymore. it's a long project.
                      u can put it in mine....as long as i can keep it after
                      my new turbo build
                        could i use the h23 crank too? If i could id' like to swap the pistons,rods and crank if possible. if so, then could i just put the h23 head on the f22 block? i know if you put it on a stock f22 block then the combustion chamber is differe,t but if i bored the block then would this problem still happen? Even if it did work would the head swap even make a power difference?
                          h23 and f22 crank and rods are the same. ive done the h23 head and it ran hard but it always smoked a little. Could never figure out why, had the head surfaced as well.
                          in the head swap, i bet you the h23 cams have more lift. pretty much the only reason why it makes a little bit more power. not worth the money, id stick with a cammed f22.
                            yeah, well if the crank and rods are the same then im going to bore an f22 block and add either a bisi cam or delta. thanks for the input everyone!
