power window switch?
    Its been about 2 weeks since my passenger window has been down. The fuse would always pop whenever in I put the ignition on ACC. So i pulled the door panels off and searched for any connecting wires. I also checked the under dash harness and found nothing. After one week, the fuse didnt pop! So i plugged the power window switch from the door panel to roll it up. As soon as i plugged the switch and put the car on ACC it blew. I tried again with just the passenger side switch and it didnt blow. Didnt roll up though because I had to plug the driver side switch. As soon as i plugged the driver side and put the car on ACC, the fuse blows. Could it be the power window switch on the driver side that is causing my fuse to blow? Would I have to replace it?
    i would open the driver side switch u to see if theres a short in it then i would replace if you cant find any but i would replace the passenger side first cause try cheapest fix first
      thank you. i will open it and see if tomorrow. the problem only happens when the driver side is plugged.
        just to be safe i would open them both up to check
          better idea. thanks again.
