Heads Leaking??
    Heads Leaking??
    Ok,so my motor is leaking coolant from exhuast part of. The head were the intake mannifold meets the. Ports, but idk? If a messed up gasket would cause that or Maybe. The Heads just cracked from that Spot?? Motor has New water pump,t-belt,Head Gasket and water neck(old one got rusted out) ooh!! And the car those Not over heat, just Smokes like Hell Plz Help!!
    Thanks Guys!!
    im not a mechanic
    but this started with mine a progressivley got worse ...basically you might have warped the HEADS its cost me about 250.00 for a brand new one but if and when you do it replace all he gaskets too ..valve cover,head gasket, intake just get i over and done with. since i replaced everything everything is very good and no more leaks oh and i also put in a new radiator and thermostat but that was just me and about 900.00 later
    Calling your USDM Accord "JDM" is like calling President Obama "African".
      I warped what?? Plz Help dnt know what to Do?
        pull the head off. then take to a maushion shop and have then check the head if warped have the head decked. warped mean the head is no longer striat it bent on the deck part of the head
          You said it leaks from the exhaust part of where the intake manifold meets the head? maybe it's just a bad intake manifold gasket... Did you check all the heater hoses connecting to or around the intake mani?
          It doesn't overheat but it smokes like hell? What color is the smoke? White? Black?
          Did you check to see if there was any coolant mixing into your oil?
          CiRcuS kiNgZ
            that happens when the shiity, o-ring in the im gasket takes a shit, water comes out in between the im and head
            Just do what PR CB7 said.
              Its white smoke, no oil/coolant mixture and its leaking from the intake side were the mannifold meets the Head (its close to the #4 cylinder) and yes I checked all Hoses and changed any damaged ones, just don't know what my next step should be take off intake manifold and check or just remove the whole Head??
                i would swap out the intake manifold gasket to see if the fixes it compared to pulling the whole head first
                  Yeah I'm about. To do that 2nite,I. Really think its the gasket cuz the motor is runnin pretty strong still, and I think if my head was cracked I would notice some kinda power loss??
                    So I took the intake mannifold off to,uncover a Worn gasket.......Changed it. And Presto!! End of tht Story, Guess that's what you. Get when u Buy Ebay?? (But. Dam whata Deal,Lol)
