Hi, New Guy here,and first I wan't to say great site !My mom's had her cb7 1990 Accord for several years.She started having some problems about 6 months ago.I have tuned it up,relaced module,alternator,battery,ignition,vehicle speed sensor,both lockup and shift solenoids in the past couple years.Not sure what her recent problem is, and when I jump the diagnoistic plug Her Slight GOES off but no codes come up.I know the solenoids have 10.5 volts going to them,and they ohm out at 28.2 .Thinking voltage shoud be 12 + volts,but no schematic on system in haynes book.Anybody got any suggestions.
S light stays on and won't start in 1st gear ?
If you've attempted to pull the codes and got nothing, then I would suspect the TCU is faulty. Replace that, or borrow a known working one from someone nearby, and see if that fixes the problem. The S light indicates an error code, and SHOULD be flashing the codes when you jump the service connector. Since it is not, then something is probably wrong with the TCU.
My problem when i couldnt pull codes was a simple fix the ecu memory fuse was blown.Easy fix just figured id let ya know.
02 Crv
