Accord axles on a SH tranny
    my passenger side axle broke on my cb7, and i need to replace it. i bought a 1990 accord axle, and while trying to install it, it wouldnt push fully in. do i need to beat on it and force it in? or should i buy the prelude axle? it slides in and stops with about an inch gap between the axle and tranny housing.
    1990 accord, 97+ SH tranny and JDM 97+ H22A motor
    My MRT!: http://www.cb7tuner.com/vbb/showthread.php?p=2800644
    The SH tranny does not fit properly in the CB chassis. Unless you did some cutting to make it fit. You're breaking axles because it's sitting crooked. Get rid of that tranny, and get a non-ATTS unit.
      yea my tranny is starting to go out too. i dont have money for a new h22a tranny...i know the f series fit..but is there anything needed to modify or is it just a plug and play type of deal.
        The F series will fit MUCH better than the SH tranny will.
        I forget if it's necessary to tap a new hole on an F series, or if that's only with the basic H tranny... Either way, tapping a hole would be the extent of the modification necessary.
