You can't just smack the nearest warm, wet spot on an engine with your ratchet and hope to fix a coolant leak.
Coolant leak
Any one suggested the Intake manny gasket?the coolant section could have went bad.Just a thought very common issue.
02 Crv
it could be the rubber o-ring(19 on left) from the metal water pipe going into the water pump
the actual water pump gasket(2), not as likely but possible
or even the return heater hose(E-15-1 left one above, #18 on the picture below) on the driver side going into the metal water pipe
oh wait i forgot about the oil cooler on some models
it could also be 13 or 14 in the picture above (not so much on the drivers side but a possibility)Last edited by quaidum; 11-11-2010, 10:31 AM.
Originally posted by deevergote View PostPlease make your thread titles descriptive. This forum is intended to be a searchable database of information, not your own personal helpdesk. You will get more help, and you will provide an additional resource for others with the same problem, if your title says more than "help me!"
Second, I have pics and a vid I'm going to post when I get to my desktop but I crawled under and had a look at things, I seen a plastic black hose runnin across the back of the block seemed to be fine but I'm thinking could it be leaking from where it goes into the driverside... more toward the driverside of the hose there was a smaller hose coming off of the bigger one that too seemed fine as well...
As mentioned, Honda headgaskets do not typically fail due to the gasket itself. It is usually lack of coolant system maintenance that leads to engine overheating and then the headgasket goes. They are quality multi-layered steel units.
Check coolant hoses before doing headgasket, it will save you much time and money with a more than likely unnecessary HG repair.
Anyhow, driver side back of engine leak could be:
- water pump seepage
- heater hose coming out of water pipe into heater core
- water pipe O-ring connecting into water pump
Just for sake of conversatio, update: I think it was the water pump afterall or atleast I would hope... I still do have a few questions...
I got everything torn apart right now, but I need know the proper steps to replaces that #19 o-ring because I do think this had a bit to do with the leak.
I feel like an ass to ask but is there a how-to on how to properly put the t-belts back together in place and in time? Because I think its outta time as well from when I replaced the heater hose under the distributor because I had to remove the distributor to replace the hose and when I put everything together and started it up it ran like poop... but all leaking aside it did run fine...
Originally posted by DoughBoy_93CB7 View PostJust for sake of conversatio, update: I think it was the water pump afterall or atleast I would hope... I still do have a few questions...
02 Crv
Originally posted by SOHC-FTW View PostYou have to get the crank and cam gear in perfect TDC.Way to do this is theres a mark on the block to line the grove up with the crank pulley mark. As for the cam timing theres an up mark on the cam gear make sure its straight up(it say UP).If you dont have a timing light this could be a trail and error type deal.The crank TDC isnt bad at all but to get the cam gear in time can be a hasule somtimes.Way ive allways done it is the old dip stick or screw drive test to make sure number 1 piston is at TDC it will be all the way up and you will fill it.Also make sure you get the timing belt tight.Much easier to do than explain and if i didnt make it clear im sure theres a write up out there for timing hondas.Hope this helps.
