front motor molt
    front motor molt
    ok will it be easy to replace a front motor molt by your self or take it to a professional.....
    CB7 all day
    mount? and yes it is easy.... floor jack, wood, and new mount. nuff said. If you have an engine hoist it is alot easier.
    CB7Tuner Resident Gamer!
    PSN: JDMcb7TX
      WTF is a "molt"?
      If you're going to ask a question, at least spell the name of the part you're asking about correctly!
      If you are indeed talking about the front mount, it's not even a load bearing mount. You don't need to support the engine in any way to remove it. just unbolt it and pull it out.
        yeah you could do it by yourself but to make things easier i would get some help just in case....but no you dont need to be a professional just some familiarity working on cars.
          Just simply slide a jack under the oil pan, with a peice of wood between the jack and oil pan, lift it just enough to see the front mount relieved, I believe its either a 19, or 17 and unbolt the 3 bolts holding the mount to the engine, and a 17 from the mount bracket on the car.
          Note - For the engine bracket bolts a sturdy rachet with a little bit of a extention and alot of elbow grease will save your knuckles, or a impact.
            Like Deev said, the front mount carries NO weight. It's just a torque mount. No need to support anything, just unbolt it and take it out.
            Originally posted by Junior Smurff
            Nevermind guys, google search works wonders!
            I don't have road rage, my car just goes faster than yours!
            Accords are for winners. And Grandmothers. But mostly winners.
            I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
              Technically you don't even need that mount. Guys with turbo'd cars don't have it, so, if the other 3 mounts can withstand the torque on a boosted engine, I'm sure an n/a engine won't be an issue.
                Originally posted by BILLYBOPROCK
                I think that's funny had me laughing I'm pretty sure he meant Motor mount.
                You are so getting your post count reset. Half of your posts are useless!
                This thread should be locked. Everything that can be said has already been said.
                  thanks guys the front mount just got put in my homie and i knock it out in 1 hours the car stop shackin
                  CB7 all day
