Oil dissapearing helpppp!
    So I have h22a and after oil changes using 10w 30 it only takes me about 1500 miles n im bone dry on oil any ideas?
    if your not leavin puddles everywhere its prob a head gasket, a compression test will tell alot
    http://www.cb7tuner.com/vbb/showthread.php?t=187851
    sold to: cb7rush\h22-accord\Luis\BurtonRiderT6
    bought from:jokerxfn-tommi-'93cb7ex
      thanks for responding as your basicly the only person to comment on about 4 different threads i posted yesterday
      ill get the compression test done today and let you know how things are looking.
      i also heard h22's burn oil like crazy...is this true?
        no my h22 does not burn oil like that
        92 cb7 http://www.cb7tuner.com/vbb/showthread.php?t=176886
        91 cb9 wagon
          How would a head gasket cause it to burn oil? Coolant yes, but oil? My guess would be stuck PCV, sticking oil rings, worn rings, or worn guides.
          Nick
            I'm with him ^^^^^^
            Accord Of The Month January 09
            Accord Of The Year 09
            My 2 Babys
            BMW TECH FOR 15 YEARS
              i shall let yall know the outcome
                So it's going through roughly 4 quarts of oil in 1500 miles?! Should be leaving a lake or massive cloud of smoke everywhere you go.
                  You said it's disappearing? Well do you know if it's burning or leaking? Check that out first.
                    the frm sleeves wear out and cause it to burn oil, they usually also have loose clearance in the valve guides.
                    I <3 G60.
                      Its not the sleeves, its that they are so hard they wear out the rings.
                      wat?
                        thats why my sleeves are worn out right?
                        I <3 G60.
