Looking at a few member's rides and bios for the best suspension listed and I can't find a common one most use. SO....what do you think is the best. This has to be one of the first big mods I do before wheels and tires. Let me know.
Best Suspension
Well it depends in what you look for in suspension. Do you want a big drop? Do you want good cornering? Do you want comfort? Depending on what you're looking for and the price you're willing to pay, you can have a whole range of setups. A lot of people go for the mixed struts and springs, but if you have the cash, coilovers are popular. If you go to the suspension thread and read the compilation sticky, it will help you see the tech specs so you can find what you want. Then read the next sticky, titled "What suspension setup are you running" and sift through those if you like.
Compilation thread:
http://www.cb7tuner.com/vbb/showthread.php?t=139318
What suspension setup are you running?
http://www.cb7tuner.com/vbb/showthread.php?t=1003
what are you planning doing with your car? if you are going to be doing a lot of road course racing or just want a really good set of coilovers check out AMR. just getting coilovers will not make your car handle its best though, you'll need to swap out your bushings for poly, get properly matched front and rear sway bars, and a good adjustable camber kit. also, good tires will make the most noticeable difference
Originally posted by Stephen Fry'It's now very common to hear people say, "I'm rather offended by that", as if that gives them certain rights. It's no more than a whine. It has no meaning, it has no purpose, it has no reason to be respected as a phrase. "I'm offended by that." Well, so fucking what?' —Stephen Fry
