bisimoto f22a turbo 2.4 cam
    Is anybody using a 2.4 f22a turbo cam. I was thinking about buying one but i can't find much info on it or any type of reviews.
    It is a camshaft. Designed to work with a turbo system.
    If you want specific info, contact Bisimoto, and they will gladly assist you. Feel free to send a PM to a member by the name of randull on here. He is Bisimoto's representative on this site.
      do you plan on a turbo build ? if not its not for you. the camshaft itself it designed to be ran on a turbo motor.
        I have a turbo build, i am the guy that came up with using evo 8 stroker pistons and h22 rods. I have a bisi 1.2 turbo cam but it stops making power at 6.5k. I want to make power to at least 8k. I have been talking to bisi, but he dont have any dyno plots to show me that his cam will make power to 8k.
        I was told by randy that some guys here have this cam
        .I HATE THIS BEGGINER POSTING COUNT
          Why? There's nothing you can't ask in this section that you can ask elsewhere... and you're actually more likely to get answers here.
          It's difficult to say exactly what a turbo cam is going to do, because there are so many other variables involved. I assume that the more extreme cam has a higher lift, maybe a steeper ramp angle. That would be the info you need to get from Bisimoto, if they'll give it, and you'll have to know your setup well enough to use that data to see if it's going to do what you want. Otherwise, the only other option is trial and error.
          Honestly, nobody knows the F22A better than Bisi, so the chances are slim that you'll find a better camshaft elsewhere.
            I Have a hx35 turbo, ported head "out flows my stock h22 head checked on a flow bench" 70mm tb, i am debating to either porting the stock intake or build a custom one.
              the bisi 2.4 is really for a more than mild turbo build. so if your just sticking a turbo kit on and just doing a turbo cam your better off with a 1.2, but all of bisi's cams are for a power band of 3000-7900, im sure you can have a tuner get you some power in the 8000's with a s200 or even a s100 and a good tune.
              but yea a 2.4 will be good if your really wanting a big turbo build (over 15lbs).
              you will notice a BIG diffrence.
              in my old cb i had a 2.3 with a 100 shot and even when i wasnt spraying i loved it.
              in my drag civic i had a 2.4 bisi cam and it ran like a CHAMP i loved it so much.
              it complimented my turbo set up very well. i was also boosting 25lbs on a good day so....yea...
                my 1.2 cam will not make power over 6500. I have talked to bisi myself a number of times.Bisi said he did not design the cam to make power over 6500 rpms. I last time on the dyno i got the car to hold power to 8000 rpms. I have always tuned my car myself. Here is my car with a small 57 trim 11 psi 260hp 280tq
                Its a f22 civic
                http://www.youtube.com/watch?v=CjPHyLHLn5w
                Car now runs mid 7s in a 1/8th on 13psi.
                Biggest reason i came to this forum bisi told me to come over hear gome ppl on here had the 2.4 cam
                cb7_with_snail what kinda power you making at 25 psi
                  cars gone now and it was a d16z6 and at 25psi i was hittin tops 510, but mind you it was a FULL build. MAN i miss it. now im trying a full nitrous build.
                  i have to say im kind of curious on a mild build at 13psi.............how are you in the low 7's?
                    sorry i re-read it 1/8th mile.
