Okay. Super duumb question... Where n how is the thermostat ground!?
thermostat ground
Originally posted by sleepygreen View PostOkay. Super duumb question... Where n how is the thermostat ground!?
How - ??? , I've no idea what you mean.
My 5.7 LS1 Holden Ute
Tough area to get a picture of. The ground is for the ignition wiring at the coil/distributor, it just happens to be attached to the thermostat housing. As ED1 said, there is a single bolt below the hose connection on the thermostat housing which is at the right (passenger) rear corner of the head.90 LX 4dr 5 spd 396,014 (sold 1/1/2022) - MRT: http://www.cb7tuner.com/vbb/showthread.php?t=201450
Originally posted by fleetw00d View PostTough area to get a picture of. The ground is for the ignition wiring at the coil/distributor, it just happens to be attached to the thermostat housing. As ED1 said, there is a single bolt below the hose connection on the thermostat housing which is at the right (passenger) rear corner of the head.
move the wire harness and ull see it, my car didnt want to start and my friend sanded the t stat ground and she fired rite up, and i changed a few things also.
are you throwing any codes by the way?**Blk Housed Slut Crew Member #1**
Originally posted by F20A CB7 View Postmove the wire harness and ull see it, my car didnt want to start and my friend sanded the t stat ground and she fired rite up, and i changed a few things also.
it doesnt connect, its a bolt and you screw it in, 12mm i think.
it goes rite under the t stat housin**Blk Housed Slut Crew Member #1**
Originally posted by F20A CB7 View Postit doesnt connect, its a bolt and you screw it in, 12mm i think.
is there anyway somebody can draw something out or something? ill go and look while i wait for the answer maybe take a few pics of what im talking about.Last edited by sleepygreen; 10-16-2010, 02:53 PM.
ill take a pic man, the best i could**Blk Housed Slut Crew Member #1**
edit-i cant take a pic, its to tight in there.**Blk Housed Slut Crew Member #1**
Code 6 is Engine coolant tempature sensor. Keep searching because it definately there because if it wasnt, your car wouldnt even fire up.Last edited by BLUBB2; 10-16-2010, 04:30 PM.
Originally posted by BLUBB2 View PostCode 6 is Engine coolant tempature sensor. Keep searching because it definately there because if it wasnt, your car wouldnt even fire up.
