code 8 help
    code 8 help
    ok i need help a.s.a.p before i buy more unnecessary parts.....
    My car on monday took awhile to start as then while i was driving the CEL cam on wich was a big surprise because the car never had a CEL since i got it... i did the codes, and only one came up it was code 8 TDC, i guess my timing was off so i went ahead and checked timing and i was right it was way off!!!...but as soon as i finished the reset timing and started the car it hesitated again to start and the CEL came onn once again it was code 8,.....I thought the code was B.Sing me so i tried to reset the ECU, still Code 8 CEL, i chaged the plugs thinking i have a spark issues but stil car hesitates to start and code 8,
    my timing is good wires and plugs are good, starter is good aswell....
    what the is going on here?.....
    .......If they seem smart, and just trying to learn, I'll offer as much help as possible. If they seem stupid and lazy, I'll do my best to piss them off so they leave and never come back... while still answering the question.
    could be the tdc sensor inside the housing
      time for a new distributor........
        yeah I ruled that out idk why though?.....well it mot likely the TDC sensor?.....
        one more question though?....do i replace the whole distributor or is it easier to just replace the sensor by opening the housing up...
          you can buy a dist housing from honda ,you have to swap your ignitor and coil......
            ok well isn't the TDC bad not the housing so i can get a TDC from the JY and just use my housing?
              if you have a lot of time and are super cheap then i guess you could.
