Vtec stop help
    Vtec stop help
    I was driving home from work when i got on the highway i tryed to step on it but when i did it sound like the vtec came on but it was not moving so if anybody had the same problem please helpand one more question what does the VTEC OIL PRESSURE SWITCH do somebody told me to check that
    92 cb7 http://www.cb7tuner.com/vbb/showthread.php?t=176886
    91 cb9 wagon
    If it sounds like its hitting VTEC, then it probably is. Car is just too heavy then if you dont feel it moving...CB's are heavy in general. just my .02
    '09 Mini Cooper S (R56)
      it come on but when you step on it it sound like it might be getting to much air or fuel dont know yet i will have to find out but i know it's full of honda oil 5w30
      91 cb9 wagon
        is the noise of "too much air coming or fuel" coming from a left or right side of the engine?? (driver or passenger)?
          i hear the aem intake get loud ass so every time i pass people it just makes a lot of noise but not moving like it use to
          91 cb9 wagon
            sounds like it consumes a LOT of air, however no acceleration, slow RPM increase. Same thing happened to me.
              how did you fix it. you can hear the vtec kick in but it act like the car not pulling hard like it use to
              91 cb9 wagon
                who said i ever did? hahaha i didnt. I've been looking for a solution forever
                I was thinking about:
                1. Broken gaskets, seals (loosing power somewhere)
                2. Vacuum leak
                3. Sensors? (No CEL though)
                4. No clue
                P.S.
                This is happening with my f22.
                  are there any cel's on?? also unhook your vtec pressure switch and see if it runs the same
                    im going to try that later on when i go to my boys house to check it out i will keep you posted on what happen
                    91 cb9 wagon
                      That's none sense weight of the car has NOTHING to do with the VTEC issue. To the OP..what does it EXACTLY do..try and type coherently. Sounds like your not hitting but not as 'hard' because it has something to do with the oil pressure.
                      Take out the pressure switch..and clean the oil screen. It could probably be clogged up with debris and oil deposits.
                      Henry R
                      Koni/Neuspeed
                      1992 Accord LX R.I.P
                      1993 Accord EX OG since 'o3
                      Legend FSM
                        Thanks bro i will try that today
                        91 cb9 wagon
                          my h22 is doing the same thing. it still hits vtec but feels really sluggish. let me know if you figure it because ive been trying for 2 weeks
                            i was talking to a guy today and he told me to check for air leaks on the intake or it might just be a bent valve on the head
                            91 cb9 wagon
                              If it was a bent valve..that motor would be toast by now. To check for air leaks here's a quick thing you can do.
                              Whilte the engine is running in idle take some brake clean and just spray it around the intake area..if the engine rpms suddenly spike then you have an air leak somewhere around the intake manifold.
                              Henry R
                              Koni/Neuspeed
                              Legend FSM
