Replacing bearings in head? Also oil pump question
    Hey guys
    I have a 1991 Honda Accord LX that is giving me some problems...
    The shaft in my cylinder head is seized up (I think it's called the cam shaft?). I believe this happened soon after I started it, when I heard a metal on metal grinding sound. (It stopped when I put in 2 or 3 quarts of oil). Right now, underneath the valve cover, the spot where the shaft comes into the head (I think that's where the bearings are?) is blackened and dry, not copper-colored and oily like the rest of the valve springs etc. This makes me think that my bearings seized up from getting too hot from lack of oil.
    My question is:
    Is there anything I should know before I take the head apart and change those bearings?
    Also: It doesn't seem to me that if the car was only 2-3 quarts low, that it would make that bad of a grinding sound when I started it. (Although it had been sitting for a while)
    Is there any possibility of the oil pump going out? (Do these cars even have an oil pump?) How would I test it? Where is it?
    Thank you much. I really appreciate it.
    Originally posted by 45below View Post
    Hey guys
    My question is:
    F-motors cylinder heads have bearings??
    www.PreludePower.com
    BB SQUAD MEMBER #28 V.2
      Hey guys
      My question is:
      You can't change the bearings in the head. They are part of the head themselves. The same thing actually just happened to my car.
      Does your head kinda look like this?
      If so, you will definitely be needing a new head.
      The CB7 does have an oil pump. It is located under the timing cover, timing belts, and connected to the crankshaft. There really isn't a way to test the oil pump other than to see if oil is flowing. If your cam has seized, I doubt you are getting oil flow. You should get a Haynes repair manual if you don't have one. It explains a lot.
      I'm thinking my oil pump went out, but only having 148k miles I'm not sure. Because I know that I probably roasted all of the bearings in the motor from oil starvation, so I'm just swapping a new motor in.
      It is possible that your oil pan may have gotten damaged somehow thus making the oil pickup, which rests in the bottom of the pan, not pick up oil. Take a look under your car and see if the black pan at the bottom of the motor has any large dents in it.
      If the motor has damage from lack of oil, it may just be easier to get a different motor rather than trying to fix the one you have in it.
      Good luck!
        No they don't, but congratulations on pointing out to the OP (who is obviously a beginner) that he hasn't pulled a honda head apart before.
        And on top of that you diddn't even give him ANY useful advice . . .
        My 5.7 LS1 Holden Ute
          The cam runs directly on bearing surfaces in the head, so if they are damaged, you have to change the head as EJX said, probably the cam as well. Even if the pan was low on oil, the head has oil wells that retain a pool of oil under the lobes and adjacent to the bearings so that there is oil there on start up. Are you sure the noise was from the cam itself? From your description, the cam still turned after putting oil in? Have you actually pulled the cam to look at the bearing surfaces? Got a picture of the area you're calling blackened and dry (not the area where the cam seal goes is it)?
            Unless he was unsure himself...
              True, and I just happened to be a a bad mood last night.
                I don't blame you... I'm in a bad mood most nights. And most mornings. It just so happens I'm in one of my rare good moods (even though I DID shut down my decal sales once again...)
                  I apologize for being sarcastic and yes i do know that we do not have head bearings. To the OP, it sounds like a new motor is the most cost-effecient thing to do here considering the likely damage.
                    notice any oil lights coming on the dash when the sound happened? or id check if the oil pressure light even works at key up.
