Exhaust
    Exhaust
    I just recently swapped the f22b1 into my 93 accord and i have the aftermarket headers and downpipe..... i wanna put on a aftermarket catback exhaust for the 93 but there is no flexpipe on either the downpipe or the exhaust... i was wondering if there was a way around this so i can have the exhaust on the car
    sounds like you bought a Megan 4-2-1 Header, withouth the flex pipe...are you running OEM CAT?
    either way best bet is to take it to a shop and have them weld you a flex pipe on there from the downpipe to the CAT....DO NOT JUST WELD A PEICE O PIPING just so you can connect the whole exhaust system, Lowered or not one lil bump or pot hole and then kiss that header good bye
    .......If they seem smart, and just trying to learn, I'll offer as much help as possible. If they seem stupid and lazy, I'll do my best to piss them off so they leave and never come back... while still answering the question.
      i was thinking of getting the high performance cat off of ebay for like 30 bucks
        you mean a test pipe?......yeah sure its not your everyday OEM RESTRICTED CAT....but its nothing more than just running Straight Piping (CAT Deleted)....
        the test pipe is the same design as having just straight piping except its resonated...worth 30 bucks? YES?
        performance?......no, HELL no...lol
        Magnaflow has a good OEM looking CAT 2.5" or 3" no big performance there but better than hearing your car donw the block in the morning and the smell of nasty exhaust fumes..
          Or just buy a cheap ebay header that come with flex pipe.
            Buy a flex pipe and weld it on the car somewhere before the cat...
            CB7Tuner Resident Gamer!
            PSN: JDMcb7TX
              why spent 60-125$ on a cheap quality piece of metal+gaskets off ebay if you just weld a flex pipe on there?
              jmells93-just have a shop weld you a flex pipe should not cost you much no need to replace what you have now if it ain't broken or impossble to do....
                Ok I will go check out a shop today thanks for the advice
