So much noise when driving
    I just got past the beginner post count, but this feels like a beginner question. My car likes to be shaky at idle, what could be the cause of this?
    motor mounts?
      Yeah that's kind of the same thing I was thinking.. How would I check to see if that's what it is? I have looked at the motor while running, it's not shaking crazily, it seems to be firmly planted to the chassis. I think the motor is shaking or something and it's so well mounted to the chassis that it's shaking the vehicle with the rest of it.
        when your driving is it shaky? or only when its stopped? you could check the engine mounts front,left,right but its kinda hard to check for the back one.
        AT WEST COAST MEET
        cb7rush: who has the tongs?
        JDMxDB8: i got a thong on...
        to get to see more of my cb click the link below.
        http://www.cb7tuner.com/vbb/showthread.php?t=130922
          Mainly just when stopped. When I'm cruising at any normal speed it ride's pretty smooth for the most part...
            could possibly b misssing mine shacked at idle but at normal speeds ok so i did a tune up and it stop
            STANCE|WORKS
              I suppose oil in the spark plugs would be the cause of the misfire. I need to replace the valve cover casket/plug seals when I get paid.
                could be bad spark plugs , when was the last time you did a comple tune up?
                AT WEST COAST MEET
                  I haven't gotten to yet. All I've been able to afford so far is a coolant flush and an oil change. I don't have any money and I just spent $100 getting the oil, oil filter, oil pan, a funnel, coolant flush fluid, coolant, throttle body cleaner, a few tools and a jack. I'm broke til next paycheck..
                    then if i was you i would do the spark plugs & spark plug wires.
                    AT WEST COAST MEET
                      you mean before or after the valve gasket job?
                        ofcourse after or they will get covered in oil aswell.Also good way to check the mounts is to have a buddy go thru the gears while ur out side under the bay listen/check for un wanted movement or harsh noises while hes doing so.
                        02 Crv
                          Ok thats what I thought.
