My car is randomly backfiring.
    Ok so I just bought my first cb7 not too long ago and it's time I start working on it. For starters I've recently changed the alternator, main relay, and battery terminals, because it wouldn't start. While we did that I took off the power steering and the cruise control because neither of them worked to begin with. Now it's backfiring randomly. The other day I was stopped at a redlight and it started idling really bad eventually it shut off. Also when I drive it from work to my house(probably 20miles) it's billowing smoke by the time i get home. And my little "Maintenance Required" light has went from loud green to like hot red. It has 240,000 miles on it. Does anyone wanna take a crack at what might be wrong with it? I could really use some help.
    That maintenance required thing is only a mileage counter. It has no idea what's going on in your engine. Ignore it.
    A backfire is due to an unburned fuel mixture being released through the exhaust valves and igniting in the exhaust system (the catalytic converter usually gets hot enough to accomplish this.)
    Check your spark plugs for oil. Chances are, at least one is completely fouled, causing the fuel mixture to go unburned. Also check the condition of your spark plug wires. Other than that, be sure your ignition timing is set correctly.
    The catalytic converter itself may be damaged or clogged. That may need to be replaced as well.
      ok I'll do that now what about the smoking and the idling...when ever it's in park it idles up and down non-stop.
        Search for threads made by HondaFan81. He made two threads, one for setting your base idle, and one for setting your base ignition timing. Follow both of them. If that idle fix doesn't help, then you may need to replace your IACV and/or FITV.
        What color is the smoke? Black is excess fuel, which is most likely since you're backfiring. Blue is oil, which is also likely if your spark plugs are covered in oil. White would be coolant, and indicates a blown head gasket. That would be the worst case.
          it's definitely white...
            Does it smell sweet?
              probably has a blown head gasket that probly why the owner sold it.....
                yeah it is kind of a sweet smell and I figure it comes from somewhere deep in the engine because it comes up through the hood and down out of the bottom of the engine.
                  Yeah, that's a blown head gasket. When that happens, coolant gets into the engine. It can do some serious damage if left as it is. You're going to have to get it fixed ASAP, or plan on replacing that engine (as well as your o2 sensor and catalytic converter)
                  Sadly, doing that job is neither cheap, nor easy... BUT you can do a hell of a lot of refreshing of the engine in the process!
                    If you got the time and tools its cheap and easy
                    wat?
                      yea, ive had honda heads off in 2 hours. it's pretty easy, just make sure you mark the timing belt.
                      I <3 G60.
                        For a beginner, it's a pretty involved task.
                          Very simple process bud at beginner lvl shouldnt take you more than a few hours if youve got the tools(10mm,12mm,14mm and a pair off chanel locks for your hoses)<--think that about cover the tools needed.Me well im known for my quickness on swaps and mostly everything else besides wirring.But i have all the tq specs needed for you also get your head shaved and decked b4 slaping a new HG on.Also id suggest a OEM 3 layer metal HG.
                          02 Crv
                            Shaved and decked (decking is done to the block)... no. Not unless they are warped. If the head is warped, it should be milled as little as possible to return the surface to a perfectly flat condition. That's it.
                            It's not a very difficult process, but it's fairly involved. It's not something I would take lightly the first time doing it. Get a good manual (www.helminc.com is the place to find the best one... the real Honda factory manual) and follow it closely. Torque specs and bolt loosening/tightening order is VERY important.
                              No id allways get the head shaved if i blew a HG or did a head swap and the head can be checked for warpage aswell as pressure tested.Ive allways done it everyone ik in the honda game has allways done it.You dont think that extra heat wont warp it?Id go the safe route a get it atleast shaved a bit.
                              02 Crv
