5 lug conversion
    5 lug conversion
    i want to buy everything new for the 5 lug conversion. can someone post up a list of everything i need. i get 60% off everything
    on the diy's its list things like like knuckle all the way to the hub and i dont know what else comes with all that
    please and thank you.
    prelude all the way in the diy forum
      odyssey way ftw!
      www.stl-imports.com
      Referral: crx08
      support the import community
        Front---
        http://www.cb7tuner.com/vbb/showthread.php?t=25357
        Rear---
        http://www.cb7tuner.com/vbb/showthread.php?t=16241
          whats the difference between prelude and odyssey way??????
            if you go prelude front, you need a 5th gen accord dr's axle, and you also need to drill the lower control arms to fit the prelude ball joint. so its more work
            go w/ the odyssey front
              Go with a 6th gen front, its a stright swap ( like the odyssey ).
              Just bolt the knuckle up to the car and your 5 lug
                ok thanks
