Okay, everyone here knows the f22 tranny is a straight up dog! But I don't really want the h22 tranny because it's really short. I hear the h23 is in between but I don't know which h23 tranny ha. Anyway what would be something that wouldn't be such a dog with my bolt on f22 and will still be good to let my turbo spool when that setup is said and done?
Transmissions(manuals)
For turbo... that "dog" of an F22 transmission is your best bet. Longer gears keep you in boost. Shorter gears require an additional shift, and will actually make you slower in the long run.
Search Google for gear ratios. It's out there. I just found many common ratios for someone else in another thread. I'd search again, but it was so easy to find that I know you won't have a problem finding it yourself.
thanks, also this may not be the place. but my car doesn't like to go into 2nd when the rpms are high. but its fine at a stand still or if i'm not getting on it. it was fine just the other day. i tried searching but tend to have trouble with search not wanting to load.IG: H2wagon
https://www.youtube.com/@H2wagon
Originally posted by gotboost? View Postthanks, also this may not be the place. but my car doesn't like to go into 2nd when the rpms are high. but its fine at a stand still or if i'm not getting on it. it was fine just the other day. i tried searching but tend to have trouble with search not wanting to load.
sounds like synchros to me...... what transmission fluid are you using?
