Will an f22 header fit on an h23 head?
    does a f22 aftermarket header fit on a h23 head
    flame on if needed
    Last edited by BadgerType; 09-28-2010, 10:44 AM. Reason: clear title for future search
    174.92 BHP / 171.45 WTQ
    I don't believe it will. Most headers will only fit if they're on the same series. I would just buy an aftermarket h23 header. You're going to make some serious power with an h23. If you're grtting an aftermarket header, most of the time the O2 sensor won't reach into the aftermarket port. So do some reasearch on the header you're getting. We're pumped to see this H23, homie!!
      yes it will fit. f22a, f22b dohc, h23 are all the same. h22 is different and so is the f22b1,2 motors.
      COUPE K24
        Just search for a H23 header to be sure. I don't think it will fit/ perform as well.
          It will fit.
          However, please make your thread titles descriptive in the future, or your thread will be deleted.
            will do deev (changing now)
            i amnot so concerned about the length of the b pipe since i will have to have a shop make a custom exhaust for my application. i just want to make sure that the top header was the same bolt pattern/exhaust outlet size
            h23 head on f23 block
            b
