It died.......again
    Very very little, I'm talking 250-500 but that was minutes before it died. But never before that
      There you go most autoparts stores will test the ignition module for free but it sounds like thats your problem
      http://www.cb7tuner.com/vbb/showthread.php?t=187851
      sold to: cb7rush\h22-accord\Luis\BurtonRiderT6
      bought from:jokerxfn-tommi-'93cb7ex
        Where is this ignition module?
          its in the distibutor, directly under the rotor usually has 4 wires and 2 phillips head screws
            Awesome, ill try to get to that tonight
              Well, I was going to check the ignition module but I couldn't find my volt meter. However I did happen to notice the following:
              The cap is cracked
              One of the bolts to the cap is gone
              It also appears that there may be a carbon track in the cap
              The leak cover is cracked
              The rotor has chunks gouged out of it
              It isn't even 3 months old
                Damn was it installd with a hammer . All jokes aside it sounds like your list just got longer, but a jumpy tach is a good indicator of the module, keep us informed buddy
                  A friend of mine at work loaned me his compression test kit over the weekend, while waiting for my assistant to get here (still isn't here) I decided to kill some time and check out my spark plugs....
                  2 of them are completely drenched in oil, and one looks a little burnt.....
                  i know this usually means something but i can't remember what
                    Sounds like you could use a good tune up I don't know if that is why it won't start at all but it can't hurt. If you have oil on your spark plugs it usually means the valve cover gasket is leaking around the spark plug tube seals.
                    Edit maybe it's these seals under the rocker assembly they talk about in this thread.
                    http://www.cb7tuner.com/vbb/showthread.php?t=166149
                    Brian
